from Diesel to Ls swap on my M1008
Cucv_M1008
Cthulhu Forever
Pendleton, Oregon
So today was supposed to be an easy work day on the truck. Well I have 6 bad freeze plugs a leaky rear main and bad oil cooler lines and a Bad IP. so Im pulling the front clip and the motor tomorrow, ill install new oil cooler lines, install a external oil cooler, transmission cooler, deep transmission pan, service the transmission, New IP, rear main seal, freeze plugs, starter and other odds and ends.
this M1009 showed up for emotional support
I see a m1008 in my future . Love the truck. Keep us posted on every detail.
might as well do a complete re-seal job on the engine Heads, Pans, Seals, Freeze Plugs, and Exhaust Gaskets. I had to remove the radiator support to do an engine R&R on my truck too because it was lifted so high, but I left the fenders on.
We are not taking off the heads but everything else is getting resealed.
