You using the serpentine setup?
Yes, will this be an issue?
You are the third person to tell me that, I think ill hold on to it lol. is this motor kinda the pinnacle of the 6.5? It does have a cooling set up for the electronic 6.5 thats after market i dont need.
Does that mean this is a mechanical-IP engine? If not, PMD cooling is a big issue in stock form.
Either way, it's not about being the pinnacle, it's just that the serpentine setup is a nice upgrade for all the 6.2 owners out there. V-belts just aren't that awesome.
That's what I think about when I hear about GMs electric IP
2 things.
First, these are fairly common parts. It is not nearly rare enough to qualify as your "precious."![]()
Second, is that boost controller set at a given value? On mine the rod threads in and out to adjust the wastegate setting. But I don't see such an option here.![]()
Will do. I thought i had seen people do this on other sites. Ty!Look online for instructions to do a homemade boost master. Ditch the vacuum operated wastegate. I bought the one from Heath as its only $100 but you don't necessarily have to if you don't want to spend the money.
Adjustable boost with the turn of a wrench.
Well when you are on a limited budget its precious to me. I appreciate your input but i dont like the way you are talking down to me.
They are controlled by the computer which controls the vacuum pump. Which when it fails will leave you with no boost, hence the mechanical swap. Essentially just a rod with a spring.2 things.
i have never driven a turbo 6.5 befor so I am in for a surpise. I appreciate all the input you have given me so far. Im excited to see how this goes.Campfire,
Thank you. Sorry for my harshnessi have never driven a turbo 6.5 befor so I am in for a surpise. I appreciate all the input you have given me so far. Im excited to see how this goes.
