Front ale seals
In looking for another picture, I saw where I had already taken one of my front axle for another member that needed some measurements.
So, here is the damage I found that caused me to have to replace the axle. That groove is right where the seal runs.
I doubt you will find yours that bad.......
Thanks for the pic,im looking foward to seeing what it looks like
inside the carreir. Just hope no major damage.
do you have to check the gear pattern or?? make sure the shims go back in the correct spot?
When I did mine, I put all shims in the same position and I ran a gear pattern...it was fine. If I did it again, I would run the gear pattern beforehand and snap pics to compare it after reassembly.
No talk of spreading the housing to pull the carrier? Don't you need a special tool to spread the housing?
