No offense, but I'm not quite sure where this explanation about a "torque sensing" versus other type of limited slip differential came from but it is not really accurate. For example, on a spring loaded clutch limited slip (aka Eaton Posi) the clutchs are applying a constant and consistent force to each other. There is nothing that changes inside the diff when one tire starts spinning that will somehow then start to limit the slip. On most limited slips (Eaton, Tru-Trac, Trac-lock, Auburn, etc...) both tires on that axle will spin up to the point in which the bias (difference between traction of the two tires) is overcome, at which point only the tire with the least amount of traction will spin. Once you have only one tire spinning you can sit and spin the tire all day long, but as long as the bias between the two tires does not change the other tire will not start spinning.
ABS based traction control systems, or the progressive "hydro-lock" axles optional in the Jeep Grand Cherokee, will behave in the manner you described....meaning that the system detects wheel slippage and then the system reacts and actually "changes" something to then limit slip.
Anyway, I have ran an Eaton Posi (carbon fiber clutches, "normal" spring preload) in my front 10-bolt for about 4-5 years now. When first installed, the truck was a daily driver and was only used to play in the mud and snow. The Eaton worked very well under these conditions, though driving on icy streets in 4wd demanded more attention. Once the truck was retired to a play vehicle and started being used on progressively harder trails, the Eaton showed it's weakness when getting really twisted up and sometimes lifting a tire as I get lift with only one tire spinning in the air.......though it is a big step up from an open diff I am planning on a locker.
I ran a Detroit Tru-Trac in the rear 10-bolt for about 4 years before swapping in a locked 14-bolt. The Tru-Trac in the rear really was not noticable, to me, on the streets and behaved very well. My opinion is that is worked a little better on the trail than the Eaton and was also more responsive in regards to lightly applying the brakes to get it to "lock up". While using the brakes got me through most trails it did make it more difficult, and once going to a true locker in the rear I did notice more of an improvement on the trail than expected. I still have the Tru-Trac in the garage and am considering installing into the front in place of the Eaton just to see what it does.
