It's got more to do with the type of wheeling/tire size/rig weight than anything else. Get your 7500 rig twisted up in the rocks a little, add some throttle and you'll be singing the "all hail the D60" song in short order.
Back country is pretty easy on parts.
I made a D44 last a long time too, on 36's and with some careful driving...that didn't make my D44 any stronger. I just wheeled within it's limits. Stepping up to a D60 allowed me to expand my horizons and worry a little less on the trail.
I bought a matched set D60/C14 with 4.56's. Gearing worked for me so no extra needed to re-gear. The C14 had the Detroit already so all I did was add rear discs. The D60 got new KP bushings/springs, and crossover. It's amazing how far you can get with an open front end and detroit rear and I didn't spend multiple thousands after the initial purchase.
Those are definitely the very high side of prices for a D60, almost to being exaggerated to make a point. If you spend $1,200 on a "basket case" DRW D60 when you need a SRW version.....well, to put it nicely it wasn't a very good investment. Then on top of that you are quoting $1,500 for gears and a locker?I’ve been running a D44 in the front of my '78 K10 for 17 years. About 7 years ago I added a TruTrac with 4:56 gears. The only problem I had was a broken axle shaft u-joint due to it running dry before the 4:56 gear and TruTrac install. The truck has a 2002 425 HP 8.1L and weights over 7,500 lbs with the camper on it, runs Q78x16 Super Swampers for local trips and 315/75/16 for all terrains for long distance trips. This truck gets used all over the back country of Colorado, Utah and Arizona. I would love to have a D60 as much as the next guy but I refuse to pay $1200 for a basket case axle that needs regeared ($500), traction devise (~$1000), single wheel adapters ($$$), king pins,…..the li$t goes on and on. Sometimes I think people read too many magazines and forums and come up with the idea everybody needs a D60 because D44's are so "weak". I guess it is all in driving technique and how careless one is with the loud pedal. I’ll keep wheeling my D44 until I really find a compelling reason to move to a D60 that justifies the cost, which I don’t see that happening anytime soon.![]()
Just to throw a quick reality check out there, Do you have a LoMax 205? line on one? They aren't available anytime in the near future/ ever again.
If you have a line on one that works then go for the lomax and put in the 44. If you don't spend the money on the 60 so you can use it harder.
On the other hand I have to agree with JMS, maybe the reality of the 44 is that it provides back up to the budget for you (Kids see a responsible adult spending within their means) and the positive side is that you have more money to put somewhere else.
If I was getting the 60 I would do a farmer overhaul with new grease in everything, and only replace whats not right. Even if a bearing is on the edge of good or bad just use it and understand that you aren't making a 2,000 mile road trip. You have good wheeling locally and even bad bearings will get you through several years I bet.
Exaggerated, eh.
Dude, check this out.
YHC63629 Single wheel hubs 216.25 x 2 = $432.50 (Randy’s Ring and Pinion)
YG D60-456 D60 4.56 Ring and Pinion $313.00 (Randy’s Ring and Pinion)
YESRP-FRONT Y.E.S. FRONT – Yukon $29.99 (I can’t remember what this part is but it was on the quote from Randy’s Ring and Pinion. It is one of the R&P set up parts)
ZK D60-F D60 & D61 FRONT MASTER Install kit $135.17 (Randy’s Ring and Pinion)
EAT915A388 Detroit TruTrac $619.00 (4WP) (this is the cheapest traction devise I would settle for, as I would rather have an ARB or E-locker)
That totals $1529.66 before you even have an D60 axle in hand
SRW front Dana 60’s are practically impossible to find around here, let alone one with the correct gear ratio. If you are lucky enough to find a D60 it is usually a DRW front D60 with 4:10 gears. In fact, here is an example of one for sale in my area now (oops, my bad…for $1250 this guy is kicking in a rear axle too…wow!). $1000 to $1200 is the typical going price for a front D60 around here.
Add your $1000 Craiglist lucky score D60 or boneyard find to the parts prices, now you are up to $2529.66 and that is before you replace the king pins, brake pads, slide pins, maybe new locking hubs and toss in a set of new HD U-joints. You can quickly have close to $3,000 wrapped up in a front Dana 60 before you even hit the dirt if you want to do the axle right before you install it. I don't cut corners so my projects tend to get pricey. I'll stick with my D44 for as long as I can or a D60 falls into my lap for a price I am willing to pay....and I am not willing to pay this much. Like Elks, I am going to just hold out and wait for the kid that has to part out his rock crawler for 10 cents on the dollar to feed his family and pay his credit card bills .
How is that exaggerating????![]()
