Front End - "Toe-In", "Toe-Out" or set for "Zero Toe"???
Greg72
@MIGHTASWELLK5
Staff member
Super Moderator
Austin, TX
Front End - \"Toe-In\", \"Toe-Out\" or set for \"Zero Toe\"???
Hi guys....
Just looking for a quick answer....I measured my toe settings on the front, and I'm currently about 1/4" Toe-OUT.
I am tempted to set it to ZERO-toe, but I thought I'd ask someone here first.
-Greg72
'72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
<font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
Re: Front End -
Think that "toe out" might be the cause of some weird "pulling" on the street???
-Greg72
Re: Front End - \"Toe-In\", \"Toe-Out\" or set for \"Zero Toe\"???
make it 1/16 toe in and it will run straight and not eat tires.
When in doubt gas it
Re: Front End -
It sure wouldn't help.
rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
I've got 1/4" toe-in with the 36" TSLs, and get the wobble of death once and awhile... I might back that off to 1/8" or even 1/16". Just my .02
<font color=red>GOT MUD???</font color=red>
<a target="_blank" href=http://home.attbi.com/~netwrite>Midwest Caravan</a>
454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
<font color=blue>Set it 1/8-1/4" in, as you go down the road, the tires will actually "toe out" a few degrees
Where exactly do you measure to figure out this 1/4" toe in? I'm about to put my front axle together with the crossover steering and need advice on how to get the toe set correctly. Thanks in advance.
Crawlin the rocks with my K5
<a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
Use a tape measure from the leading edges of the tires, and then measure the trailing edge of the tires. The trailing edge should measure abuot 1/4" wider... Hope that helps...
make a line around the circumference in the centre of each tire,
measure the distance side to side, as stated above, at the frontmost and rearmost point of the tire
subtract the 2 to get toe number
as too what to aim for,
with wide swampers and city or off road driving i would toe out, better turning radius and turn in
highway, you just shouldnt be there with swamps
formerly 77chev
still a jerk though
