I was going to vote no on the whole light thing. Mine I think is mabey just a touch wider than yours maybe about the same and I wish that I had gone as far in as I reasonably could have.
Looks cool for sure though, no real reason to have the black tube in there.
At some point you are just adding weight with out much real benefit.
Me too. I think you have inspired me to cut up my core support and go this route.
Cut it up so you can ditch it?!
Its so easy to mount the rad without the core support, I used the original lower mount ( cut off the core support) and made brackets the upper originals bolt to. mounts with stock components but no core support
On the fenders, where you are mounting the front make sure that the area on the fender is supported very well. even adding a couple of braces between the inner and outer skin would be good.
Thats how I mounted mine the first time I did it, the fenders ended up pulling away and breaking all sorts of crap. Course it didn't help I was occasionally hitting them but thats besides the point, if I would have beefed up the mounting location on the fender it would have helped alot.
Not saying weld some 1/4" in there just some sheetmetal braces
I like the hood. Why doesn't it fit up by the firewall? You didn't cut up there, is it just a flaw in the hood?
How'd you layout the cut? It fits the taper of the fenders really tight.
The pics show why it doesnt fit. those dang ribs under there are hitting the firewall. Im wondering if i can cut some away without damaging the structure of hood?
It looks like its because everything is a little shorter because of the narrowing.
I know, I saw the ribs thats why I was asking if you had the hood situated funny because of the fenders or if it just plain doesnt fit because it was molded wrong. Is that hood for your year blazer?
