Kain
3/4 ton status
sucks that its bad again, wonder if all the water is shorting it out?
i play in a lot of mud and water
thinking about cutting an access panel and patching it in so i dont have to drop the tank to switch it, what do you guys think about that?
Now take that wire and ground it. If it goes past empty, the problem is something with the tank or wiring to the tank. The tank ground is the most common problem IF you do the test and find the gauge responds correctly when grounded.
FWIW I don't think the "mid point" of the gauge reading means anything. I've never seen a gauge that was correct on either end of the scale, but off in the middle. May happen, just isn't common, at all. Gauge failure itself is not common at all. It's almost always a wiring/connection/sender issue.
It's common enough that I've had three different square body rigs that had bad gauges...and none so far that had bad senders.![]()
