CherryK5
I'm one linking the rear, yea yea, flame away. It suits my needs and driving style and its in my knowledge range and budget. I'm using cat clamshells and grader ball.
Looking for ideas/pics of you're home made coil spring buckets or mounts.
Think zero budget, i have steel, a welder, and a plasma cutter so i can fabricate whatever, just looking for ideas.
I was thinking some tubing to center the spring, welded to a round plate, with a chain running through the middle so i can let the spring ride loose up top and drop a little at full droop. And the same thing at the axle only clamped to the plate via j hooks or small u bolts
