CherryK5
You leave that poor jimmy alone Eric!! Gawd DA****T you leave it the **** ALONE!!!!
Why not improve on an old worn out suspension. Dont hate.
Im only two inches over stock.You should encourage me, cause its going to stay low and small tired,
now quit messin up Cherrys thread![]()
hence why my geometry is so good.
That's some pretty sweet back yard engineering right there.
I really think it could benefit from a lower arm running from under the axle tube to the link arm. One on each side. That would take some of the force off the spring perches and the u-bolts. They (the u-bolts and leaf perches) wouldn't have to counteract the axle twisting force just hold it in place. Would look kinda like a radius arm style set up, just connected at the front with the one link.
If/when i rebuild it, i'm setting it up with rubber bushings exactly like a radius arm. But not until i figure out what size tire im buying next and set my wheelbase so i can have a permanent (lol) setup
This is a cool diy setup, me likey
But I have some concerns...
I agree.
With leafs springs you have something like 7-10 sqare inches of leafs next to the spring perches to counter act axle wrap, and thats on both sides.
Now you've got maybe 1-2 square inches instead.
I know it's comparing apples and oranges, but you get the picture.
the perches are the same size as a stock perch. So really nothing on the axle is different. You just don't have any give from a spring.
It think it's just a matter of time before it will break.
But one single tube on each side from the axle that attaches maybe a couple of feet forward on to the link, would make a huge difference.
There's really not any reason to use bushings, since you dont need or want any flex there.
Unless it's street-driven and you want to keep vibrations down.
But I'm guessing this truck is a trail only rig?
I would bolt it directly to the axle, with one point down at the tube and one in about the height your current link is attached
Nope, DD weekend wheeler, until I get a second vehicle. But everythig I've done lately has made it drive better, and actually made the dd part much nicer. Contrary to what the internet said, full hydro made my truck 15 times nicer to drive on the street, and for the price of this suspension setup, its unbeatable, and makes leave look like a joke. Im glad I went with both of the upgrades.
What kind of joint do you have between the link and the crossmember btw?
pics?
Standard grader ball off a t600 motor grader[/QUOTE
Dont know how, but im into my third 2lb spool of wire on this suspension.![]()
That's two separate welds jerk.
One welding the square tubing to the round stock. And then the panhard mount just happened to end up right on top of it.![]()
It was just too good of an opportunity to give you grief.It was just too good of an opportunity to give you grief.
It's not the perches I worry about, I think the link-tube just in front of the perches (where your double weld is) will be the weak spot.the perches are the same size as a stock perch. So really nothing on the axle is different. You just don't have any give from a spring.
Cool, I've never seen one of those. I like it
It looks like you can adjust the play in it when it gets worn, is that correct?
How much does one of those cost?
