CherryK5
Frenchie, would you stop goofing off about off road stuff. You don't know how to weld dear. lol!!!!!
Frenchie is my girlfriend.. and frenchie can weld.
Don't use the chain to limit droop, capture the coils up top.
This helps a ton with stability on a blazer. I have one linked 2 blazers. We ended up capturing the spring top and bottom on both of em, it just worked better overall.
Keep the wishbone as flat as possible, I realize you have already built the pahnhard but it needs to be as long as possible too.
Good luck with it, one links work decent most of the time but I have seen a couple that didn't work very well at all
What are those coil buckets out of? They look cast and you're welding steel plate to the sides?
You can add steel all you want but if they're cast iron it'll crack apart the way you're doing it. I'm all for budget builds but there are just some things that aren't worth skimping on. This is one of those areas...
I have welded steel to cast iron on several occasions and never had a problem with it breaking. Just make sure you get good penetration and check the welds for cracks when you're done. If it cracks just grind it down and try again.
