If people are interested I could, I learned a lot, but it was a lot of work, over 100 hours. I have more pictures but didn't sort through them all.
I know I for sure would be interested. I imagine most people on here would be.
Martin
I think there are pros and cons of having the interface on a touchscreen. I wouldn't want to need my phone every time I used the mill, so it would need a dedicated tablet. Plus the mill is a messy area when in use with metal chips and lubricant getting slung around. So a touchscreen might not be very reliable if it ends up with lubricant all over it, like when you get water on your phone screen.Speaking of dro, anyone used the touchdro, that's run off android tablet?
TouchDRO - Touchscreen Digital Readout (DRO) for Lathes and Milling Machines
TouchDRO is a touchscreen digital readout for manual mills and lathes. Designed, assembled, tested, and shipped from Portland, Oregon, it supports most common DRO scales and has been trusted by machinists since 2012.www.touchdro.com
Impressive rebuild!I cleaned, rebuilt, and repainted everything with 3M industrial paint. New oiling system parts...
I also added a 4 axis DRO, so it even has a DRO on the quill...that took some mill work just to mount it all with a custom switch panel to control the VFD.
Had to mill some flat stock and T channel after milling mounting counterbores and threads into the quill stop thingy...
View attachment 469353View attachment 469354
Was almost done, shortly after I sold that vice and bought a new Kurt vice....
I added power feeds on the knee (Z) and the table (X)...
Steel building tools. Bottom one is a Spud. Don't know what the top one is called.Here's a challenge for CK5- what are these "tools"? Look to be blacksmith made. 5-7" long.
View attachment 469365View attachment 469366
Thank you, it needed some work after ~5 decades of use.Impressive rebuild!
Add another vote for full on write up and a ton of pics - looks great !Thank you, it needed some work after ~5 decades of use.
Martin
In our plant it is mandatory that a safety catch strap be used on every mag-base drill - not just in case the operator hits the wrong switch but usually it’s some other idiot that has unplugged the power source. Those would be the folks that have no business working in an industrial environment but sadly they are there in increasingly higher numbers over the past few years…I was thinking the same thing, a strap through the handle around the frame while in use so if it falls it doesn't hit the ground.
We have one at work and it is very good.They have new ones that don't require electricity for the magnet to work, but they are almost $2k! And the M18 version is ~$2600, crazy.
