got some $128.99 ebay stainless steel headers. pics inside
i think ill order some cant get my hookers to seal keep blowing header gaskets
i have tried percys, remflex, coppers, steel core laminate , mr gasket papers nothing does not blow out
even summit says thats why they changed design to a flat flange
im going for the full length ones, but thanks for the link
Figured you might but for anyone looking to package the exhaust tighter for clearance would want shorties or mid length.
About a year. They’ve probably only been through a dozen heat cycles.
Any long-term reports on these eBay stainless headers?
I have the black version of these headers from the same seller as the original post. They are almost 3 years old and so far they seam to be holding up well i have had to re torque the bolts a few times but that is to be expected with any header. Only problems I have had is the front drive shaft has hit the collector flange when flexed out. But I think that is because I have the transfer case clocked up.
I’ve been holding off doing headers on the sbc since I know the bbc is going in down the road. But it might be worth t to clean up the engine bay and get rid of all the air pump crap
