dieselndixie
Im not taking the door panels off, but I am taping and wrapping them. Same with the dash area, and the sides. When I did my jeep, I made like a cocoon and sprayed inside it.
I needed some simple reward, as I feel like I have been working on the same thing for too long already. Im done with the sanding, and now Im waiting on my cousin to return my welder so I can "fishtale" the last crack in my floorboard. I also have the rest of the taping up to do before I can spray the bedliner.
So, I decided to start cleaning and painting the spare axle, because at this point I really think I am going to switch over to it. ( I need info on how easy it is for me to move the locker and the hubs over to the spare axle ) rather than put the speedi sleeve on the current one. I think now is the time to do that, but I dont know if I can do it myself, can I?
How well are yall cleaning your axles before you spray paint them? I am using my angle grinder with a wire wheel...as well as my drill with a smaller wire wheel. There are lots of little nooks that I cant really get clean. I seem to only be able to get the main open parts clean and down to metal. I was able to clean up the diff cover and spray it with some engine enamel. felt good to get something done other than sanding.
