GsxrMike
Well here it goes...
Some of you have seen lots of these pics as I have been posting with questions about this or that. Now I guess its time to start the ol' build thread! Tell me what you think. Anything I should change? I started with an '86 K5 blazer, mildly built 350 (haven't heard it run yet) but took of the intake manifold (edelbrock performer) to replace an intake bolt that had broke off and found it has a roller cam!
MSD dizzy, I put in new plugs (NGK hot plugs stock gap), accel coil, accel cut to lenght wires. I hope the timing is real close because the drunken buddy that cut the wires didn't give much play! It also came with headers and dual exhaust with H pipe. I ran the casting numbers on the heads and found they were 1.94 intake, 1.5 exhaust.
The blazer didn't come with a drivetrain but had a 14BFF read 10B front with D44 hubs. Both open with 3.73s.
I bought an '85 M1008 that had 14Bff/4.56/Detroit and D44/4.56/Open, with a TH400/NP208 to swap in to my K5. I installed a shift kit for RV/Offroading with full valve body contol. The blazer also came with a DIY4X shackle flip with 64" (I think thats right?
) rear springs and 52" front springs. He threw in a flat top knuckle that had been milled and drilled. I just ordered a 1" body lift, crossover steering, and zero rates for the front (sat a little lower in the front) from ORD and new body bushings from energy suspension parts.
So far I have sandblasted the frame and painted it with POR15 and rustoleum flat black top coat. Same with gas tank. I've started reassembling everything so here are some pics...
Frame after POR15...
Body hanging around after chasis removal (in my basement BTW)...
Here's the frame before I knew I was getting new axles...
Shot of the motor installed...
Drivetrain coming together...
I've done about 85% of this crap myself because the only guy that really likes doing this stuff is very busy (and married). Tell me what you think, what looks good? What needs changing? Thanks...
(BTW: I'm sure i've forgot some things so if you have questions ask.)
MSD dizzy, I put in new plugs (NGK hot plugs stock gap), accel coil, accel cut to lenght wires. I hope the timing is real close because the drunken buddy that cut the wires didn't give much play! It also came with headers and dual exhaust with H pipe. I ran the casting numbers on the heads and found they were 1.94 intake, 1.5 exhaust.The blazer didn't come with a drivetrain but had a 14BFF read 10B front with D44 hubs. Both open with 3.73s.
) rear springs and 52" front springs. He threw in a flat top knuckle that had been milled and drilled. I just ordered a 1" body lift, crossover steering, and zero rates for the front (sat a little lower in the front) from ORD and new body bushings from energy suspension parts.So far I have sandblasted the frame and painted it with POR15 and rustoleum flat black top coat. Same with gas tank. I've started reassembling everything so here are some pics...
