GsxrMike's build thread...Frostbite 2011 Pictures are in!
If you run an aftermarket regulator the fuel pressure gauge will run off it most likely.
I'm not worried about where the gauge is going to be, I want to know if I set up my fuel line like that if it will work to feed my throttle body.
Then yes, that should work fine. I have run that setup before on 500hp multiport injection systems and it worked great don't see why it would be any different on tbi.
I use needle nose pliers to change mine after installed. How often do you plan on changing the pressure?
Not really sure how you're adjusting it, stock regulator isn't adjustable. I know there is some aftermarket stuff out there but it's not cheap. Can you post up some pics or something? The way I did it seemed the easiest to me. Merry Christmas!
Done again!
So we got all of the tbi stuff hooked up and it runs, we tubed the front and plan on adding some skin but other than that it is finished again for awhile.
Frostbite '11 Pics
Here are some pics from Kansas Rocks Park this last weekend. The tbi and beadlocks made a huge differance. HUGE! :D
tcase popping out of 4 high?
Cuz I used to use a ratchet strap to keep my 241 in high haha
Yeah when the body flexes just right it knocks it out of 4 low. I could probably adjust it out but the strap works good. I tried to shift it into 2 high the other day and it stayed in 4 low so something is broke. At least it is stuck in 4 low.
Holy bump!
I was actually just thinking of this thing the other day.
Martin
