Had fun today on the side of the Freeway 35" blow-out.....
Re: Had fun today on the side of the Freeway 35\" blow-out.....
What is super hot weather ?
Is 32 psi kindas on the low side ?
hmm
short trip and not super hot weather
how did the tire get hot enough to peel the entire tread surface off?
odd one
keep an eye on the rest of that set
in the 100s is hot
when it gets in the 100s you will start seeing a lot of hiway trucks having tire problems
when it is that hot I slow down a bit and check tires every time I stop (I check them a lot anyway)
as for the pressure it depends on the tire
if you have a bulging sidewall then you are working the tire and heating it up
your call on whether you take the harsher ride or reduced tire life
The tire was in great shape when I started that morning... I normally look at the outsid of each tire on the truck & trailer before I drive (left over from motorcyle riding) No bubbles or I would have changed the tire...
Just one of those days..... Big O employee said I may have hit something in the road... Could have been but didn't see anything that day.....
Thanks, is there really a diffrerence
between 95 and 100 F ?
in the 100s is hot
