Its gotta be better than not having it!!
Thats what mine from sky was too from 3-4 years ago. Mine held up good too, just sold it to a guy in Hawaii few months ago with arms. It just looked small with your ram mount on there!![]()
Well now I cant steer at all. I must have cycled the steering 150 times. Still bubbles in the fluid and it still feels the same as the very first cycle. Its kind of hard to turn with the tires off the ground. There are times it gets easier for a turn or two, but then gets hard again. Kinda wierd that it hisses when I shut it off..is that just air escaping? Is there a chance it could be sucking air anywhere, or wouldnt it leak there as well? There are no leaks.
This is a used box and the original pump. I have a new box and I may grab a new pump tomorrow.. FML
This sounds dumb, but have you maintained fluid level through all your cycling? Did it ever run low? That will allow the pump to suck air...just like bleeding brakes.
Good luck.
Grille back on a freshly painted core support. Pretty much looks like a factory restoration now
Your tow hooks are the wrong color![]()
They were a dealer installed special option![]()
