txfiremank5
I like the sliders (and so do my kiddos), but I keep a spare set of solids around in the event I ever feel like going that route. I guess it's nice to have options.
lochenjons said:The sliding ones are a lot heavier, cant really imagine why there'd be such a difference but compare with my buddies full glass from a '78 and my '77 sliders mine is significantly heavier...but then again who needs a top anyways
dyeager535 said:I've had both, our climate is similar, not worth it IMO.
They leak, parts are harder to get (and there are way more) the wing windows loosen up, the screws holding them together are steel and the frame is aluminum (so they won't come out if you need to try and fix the wing windows) and so on.
Metrodps said:YES it really helps I open them about two inches and lower my windows a couple inches. No hard wind on me and great flow! If you have kids it gives them a break from wind also And you did see mine do not leak? Also the link I listed for parts did you check it out?
Metrodps said:I will address this:
Leaks can be fixed with new felt, Latches can be replaced and wind wings are either out or in so I see no problem there. As I posted several times PARTS ARE AVAILABLE! http://www.cheyennepickup.com/
I suggest reading this http://coloradok5.com/forums/showthread.php?p=1794069#post1794069
dyeager535 said:Doesn't hurt to keep the sliders around for a bit, swapping them isn't too hard. You can always try them and see how it is.
Yea but toppless is even better.chalet2506 said:Sliding windows are best, they're a lot easier to shoot out of.
My$.02
