bp71k5
3/4 ton status
Touche!
Well, I just grabbed a piece of 2 1/2 tubing from the local mom/pop auto parts store, about 18" long, and it JUST sneaks right in between the area around the tcase. Fits right inbetween the lower shackle, and the support going from tcase to transmission mount bolt. Looks good to me!Did you get any more of the exhaust routed?
Curious as to how you will deal with either a Y pipe or getting the exhaust past the passenger side at the transfer case.
pic with the headers in
yep, locking dipstick straight from the dealer..Is that some kind of locking trans dipstick? Mine always works it's way out about 1" and it's time to replace it anyhow because the ring broke off.
Your dipstick pops out cause you have to much crankcase pressure.
do you have a functioning pcv?
Do tell...I assume you mean the engine dipstick? I think it was either a Mr Gasket, or a Spectre.I didnt know trannies had pcv valvesDo tell...
Hey Ben, is that a Lokar dipstick or other brand??
So much for being a smarta$$
The pics wouldnt load in the quote, and I was going off his words which said trans dipstick. Does that stick just lock or does it have pretty good sealing provisions?Yes on both accountsSo much for being a smarta$$
Thanks man!Thanks. BTW, your buils is lookin good![]()
AHA! Ive been caught asleepYup sorry Ill try to pay attention next time
Yea sure they do......... dont they?
I do know that trannys have a vent and if its clogged it will do the same thing.......
comes with the march alternator bracket. i have the march bracket for v belt i don`t need, pm if interested.OK, I gotta have one!!!! Where did you get the turnbuckle alternator arm???????? If this is something you built, PM where I can send you the funds for one!!!!!!!
