yup, shop vac the heck out of it.. than lay some paper towels in the lifter valley with a couple rags laying on top to keep any more crud from getting in there when your doing the head gasket...
I thought the amount of caked oil I saw in my 305 was just from someone that never changed the oil. Incorrect? Does this happen even with regular oil changes?
like 80, 90 g's with no changes..put a hammer handle, etc in an exhaust/intake port and pop it up.. it has 2 locating dowels to keep it from sliding around on the surface...
and as mentioned, that bracket is just bolted to the head, you can take it off after the head is off...
did you drain the block?
