Well, got a hole drilled and tried the EZ out, broke it, but looking back I wish I could have found a larger one. None of the GOOD hardware stores are open after work, only OSH/ HD etc. The hole was ~ 1/4". I heated the casting around the stud and below it a bunch, sprayed PB Blaster and watched it suck in. Heated it again and watched it come out, bubble around the threads, and suck back in with heat removed. Pounded a punch around the hole and at the bottom of the hole. Then, pounded the EZ out into the hole. Didn't take much to break, which is a theme for EZ outs. I've broken every EZ OUT I've ever tried. I feel like I need a $200 super strong one for it to be worth even trying.
Now I've got a broken EZ OUT in the hole, luckily almost flush to the top of the stud because that's where I twisted it from, way down low.
I used some bits I bought at OSH. They had a shovel head look to them. And I tried a Craftsman Cobalt one that seemed good. I'm wishing I just spent the money on several and just drilled it out close to the threads. But now I've got a piece in the way LOL.
Have you got room alongside the EZ for a bit? You can drill small holes around the EZ and get it out.
Got lucky that the EZout went in without drilling anymore and that the broken EZout was far enough down.
Oh, and I welded the shim to the U-bolt plate. Looks bitchin! (I notched the shim so it goes around the center pin, so this isn't it's final position)
