Help..700R4 valve body ball bearing placement
phrogs
Registered Member
Kalamazoo MI
Guys I need some help with the placement of the ball bearings in my 700 R4, and are there any that should be removed for it to run better?
this is completely stock no shift kit is installed
just wondering what some of you have done.
Sugestions are welcome
It's a 90 700r4
thanks
You can leave out the one next to the second gear accumulator on a 1990 model but leave the rest as is. Any shift kit you use will have drilling instructions for improved flow through the seperator plate.
