bassplayer4x4
Ok, ordered a new wiper washer switch as there was not one in my vehicle. Just a hole in the bezel. Installed switch, hooked to motor via lt blue, dark blue, and black wires. Turn on switch and motor begins moving wipers, however switch has no effect on them -- they won't turn off. Take switch out, wipers don't work at all, touch switch assembly to dash and wipers work -- it arcs between switch and dash. I am assuming grounding problem somewhere. I took out my multimeter and touched it to wiper switch and to dash bezel read about 25 volts...I noticed that when my motor was rebuilt the battery is not grounded to frame, but grounded to block? There is a small lead off the neg battery terminal hookup that I could extend and hook to frame somewhere -- any ideas? Also looks like entire dash electronics are grounded to the big brace under the steering wheel. Bad place? Horn does not work either, but I figured that was in the button, some gauges work -- some don't, fuel works but reads backward (reads full when tank is empty) Speedo and tach work, battery/alternator work, niether of the two temp guauges work, oil pressure works. Advice? Ready to pull my hair out. But don't want to take it to the electrical guy in town -- he is expensive...especially if this is an easy fix.
Also looks like my fuse block was updated too, has fuses for power windows and stuff which was not around on my year vehicle. I am thinking a full wiring harness redo when the restoration was done.
Phillip Bunton 72 K5 and 4Strings
But honey its cheaper than car payments!!
72 K5 - my First First Gen -- 4 K5's to date...
Most of the time I just use a sports bottle over the windshield because I never use the top.
