Well,my friend got his "new barely used" Rotary lift installed Monday..
Its actually a 9,000 lb unit--the 10,000 lb one would have required major mods to his shop bay to fit in it,and any truck large enough to fit on it would not fit in the bay anyways--the garage is basically a one car garage that is about 30 feet long and they had to cut out an opening in the ceiling to allow a vehicle to be lifted to full height..
Hard to explain,I'd have to take pictures to better describe it..
The lift looks brand new,it was only 5 years old,a landscaping company had it installed to use on their own small fleet of trucks for oil changes and minor repairs,then after it sat idle for 2 years,the company decided to just get rid of the lift (and their "on call" mechanic),and just send the trucks out to be repaired elsewhere..
The guy said he gets a lot of "hardly used" lifts from similar instances,when an older guy buys one to work on his old cars,and ends up dying,or sick and needs the cash,etc..happens a lot I guess..
This lift has the uprights tilted at an angle,so you can open the doors on a vehicle much wider without hitting the mirrors or door on the lift,it is a foot or so wider than the old lift too..
The guy sold it to him for 1800 bucks,and installed it ,wired it up,etc,for a total cost of 2500 bucks,and he's giving a 6 month warranty on it,same as if it was a brand new one..
It looks like it was never used..
He also was going to fix two large transmission jacks and an under the lift jack,but it turned out the only thing wrong with them was the oil filler plug they put in them for shipping purposes,was left in,instead of the correct "vented" filler plug being put in!..all that they'll need to work properly is to drill a tiny hole in the filler plug...
The guy seemed honest,he could have made a killing "fixing" those jacks...
The guy said the old Global lift was a "total P-O-S,probably one of the worst designs there was,and over complicated,the only good thing about them was the uprights were built like tanks--each one weighs over a ton...but he also said that design is now outlawed,and even if he had a brand new one "leftover" from the era this one was built,he could not sell it "legally"...he added "your lucky you ain't dead,working under that thing so long,you were on very thin ice"..
He pointed out two cables on it that were replaced in 2015 were already frayed and ready to snap..and he wishes anyone who buys the old lift "lots of luck" trying to re-assemble it--he's had many of them apart and said they are a real suck pill to get together and make work right again..
Now I want a lift more than ever...doubt I'll ever be able to get one though..
