I would not do that until you get it to start...taking the injectors off will let the whole fuel system get airbound again...most likely it just needs the glow plugs activated,maybe some are dead or shorted...most 6.2's wont start even in mild weather if you dont have at least 4 or more glow plugs working--in colder weather all 8 ,preferably..
When I first got my diesel pickup it was all butchered as far as the fuel lines to the dual tanks--I had to resort to using a small gas tank (aka bleach bottle!) and I put the fuel line and return line in the bottle (under the fuel,submerged),and it took a long time and several attempts before it showed any signs of wanting to fire up...
I killed the batteries 3 times and though I warn everyone NOT to use starting fluid--by day 3 I was ready to pull the diesel out and put in a 350 I had--I didn't energize the glow plugs,and had someone crank it over while I sprayed the ether in the intake...it fired up and ran,and once it ran about 10 seconds,it kept running..
Starting fluid use is risky--even if you do not energize the glow plugs,it can still do internal damage to pistons,rods,and valves...never use any if you had the glow plugs "on",it'll be sure to pre-ignite...wait at least 10 minutes if they were on..
I'm not telling you to use ether,but I'd try it as a last resort,before pulling anything off it or apart..first I'd make sure the glow plugs are working ..
