Question about trac bars in general.
I've seen them both with and without a shackle in the front. Does that really matter? Are there and good tech articles about building a DIY trac bar?
Or should I just wing it see what I can come up with?
My SRW 14b FF came with a sway bar and mounts on the axle tube. I junked the sway bar, but left the mounts. They look similar to 3 hole spring perches without the center hole, and they are welded on the front of the axle tubes. (I can post pics if needed)
Anyway I thought they would be perfect to use for trac bar mounts. I was kind of thinking of making a Y shaped bar and welding or bolting a skid plate to the bottom to protect the drive shaft and pinion.
Thought?
