y5mgisi
1 ton status
Roger that.
So I'm just about ready to apply some filler. I'll get the duraglass and rage gold. So to apply the duraglass, I should sand the area with yonderish of 36 grit on the bare metal. Correct? And then if I need to apply rage gold in an area that spans from the duraglass to bare metal, what grit should I be sending that with? Finally, once I get the entire panel ready to prime, what grit should I use for the first primer layer, and what primer should I be using? In my research I have read that it's best to epoxy prime. Is that true?
