G gunner2000 Registered Member Joined Mar 25, 2006 Posts 30 Reaction score 0 Location bentonville ar Apr 9, 2006 #1 need a littlie help on a timing problem
Muddytazz 1 ton status Joined Jun 30, 2002 Posts 20,072 Reaction score 2 Location Salem, Or. Apr 9, 2006 #2 might get better help if you were to post this in the Garage
1985_K5_Silverado 1/2 ton status Joined Dec 21, 2005 Posts 984 Reaction score 0 Location Corn Country Apr 9, 2006 #3 gunner2000 said: need a littlie help on a timing problem Click to expand... Can you be a little more specific?
G gunner2000 Registered Member Joined Mar 25, 2006 Posts 30 Reaction score 0 Location bentonville ar Apr 9, 2006 #4 87 tbi, went from a 305 to a 350, now i can not get the timing to set, went by the specs the cam came with, 5 btdc
G gunner2000 Registered Member Joined Mar 25, 2006 Posts 30 Reaction score 0 Location bentonville ar Apr 9, 2006 #5 87 tbi went from a 305 to a 350
dyeager535 1 ton status Premium Joined Dec 13, 2000 Posts 31,577 Solutions 1 Reaction score 2,914 Location Roy, Washington Apr 10, 2006 #6 You disconnected the bypass wire (lots of posts describing the wire on this board) before trying to set base timing, then set base timing at 0*? 5* is a lot of additional timing, most that have tried timing that far advanced on TBI haven't had good luck.
