upload them to photobucket and post.
Or just post a bunch of replies.
and now, for todays grand entertainment.....
well this is stupid...i tried uploading the photos from my iphone and it wouldnt work and now im on my ipad and its only allowing me to post one pic on each reply...any help?![]()
do you mean once i flip it around and do a spring under?So whats the plan now? Flip it back around and weld perchase on the bottom? Really you dont even need to screw with cutting the old perch off if you use regular U bolts and ditch those pad things.
Yeah I still have the stock round ones that I removed. But the perches ontop would interfere with the U bolt clamp on top if I didn't cut them off .If you wanna do the spring under still. You really wouldnt even need to cut the old off. Just weld new ones underneath. Idk if you could use those square u bolts etc though.
Or just put the axle on the bottom and be done with it.
I'm confused here.. just take the axle out.. flip it around and put it under the leaf like normal.. use rounded u-bolts and upper spring plates... that rig is sitting stoopid low, if you install it correctly, it will sit good...
In most John Deere tractors you can set the ring gear carrier in either way. It will drop right in. A kid at the local John Deere dealer I use to work at, accidentally installed the carrier in an articulated 4wd drive tractor backwards one time. No one noticed (he was a college kid at the time on his coop quarter), and he put it all back together. When he started the tractor and put it in gear it would just kill the engine. They finally figured it out, because when they would start to let the clutch out, the tractor would either try to pull apart, or squeeze together.Haha. That's awesome.
4wd burnout and not move anywhere would be pretty cool![]()
So not only is it up side down but its is on top of the springs
You know it mounts under the springs ?
