help with 14 bolt sf 9.5" swap on 81 k5 please!!!
So finally got the blaze registered this morning and spent all day redoing my rear axle swap and SUA rear suspension. Went out for the first drive tonight and of course, get pulled over....:dunno::rolleyes:....but the cop was cool and only gave me one fix it ticket instead of 10:D. But the suspension was pretty good. Really bumpy tho and it seemed like at times the rear was hopping. Not sure if the rear was actually hopping or if it was just the suspension. Any insight on this as I've never actually experienced this first hand before? Thanks fellas!
Re torque your u bolts
I Pulled Engines And Trannys For A Rattle That Was A Craftsman Screwdriver In The Fender. IT Happens.
yeah, years ago I changed my fuel pump pulled all of the gas lines and dropped the tank... turns out I was just out of gas.:doah:
Does it still sit like in your pictures!??
Sure it`s not riding on the bump stops?
That's funny. The fact your owning up to it is even more awesome.
Once some years ago we were ready to start tearing a brand new motor out of a car. Buddies dad came out and mentioned we might should hook the battery cables up.
We were also dead tired
^^ this! It takes some guts to 'fess up...especially with this crowd!
Mass attack of oh chit...:pimp:
(been there :whistle::whistle::whistle:)
This crowd is nothing.
The Pirate douches would be a different story if he posted there.
yes indeed. that's why I'm here and not there.:thumb:
Any luck figuring it out!?
Yeah! I'm still messing with the shackle angles and hangar placement/gusseting. I'll post some pics when I get it all dialed in.
But the original problem that was resulting in the rear hopping and making noise was I didn't tighten the U-bolts after I put the wheels back on which caused the axle to move which then caused the welds to break on one of the spring perches :doah::thumb: but gusseted and re welded the perches on the axle, and now mounting the spring hangars down lower on the frame for increased ride height in the rear without as much sag. :woot:
That's good! :thumb:
Jess Nailed it!
