NEK5
3/4 ton status
happened to me...blew the front toomuddybuddy said:it happened to a buddy of mine....he had a govbomb in it tho
jms said:Considering this is ColoradoK5.com, this is one of the funniest lines I've read on here in a long time.![]()
MuddinManny said:Why is this the funniest lines you've read?![]()
MaxPF said:To me it is simply an 8-lug vs. 6 lug issue. If he is trying to choose between an 8 lug 14bsf and a 14bff then it is a no-brainer: 14bff. OTOH if he wants to stay 6-lug (which means he will NEVER go bigger than 37's) then a 14bsf is the only sensible choice. A 14bsf will handle bigger than 37's, but the 10b/D44 front wont, so if he plans to go really big he had best get the 14bff and be prepared to do a D60 in the future. But then, you already know that![]()
MuddinManny said:The issue here is that giving bad, self centered information to youngsters in this hobby is NOT the right thing to do.
sandawgk5 said:I agree there is nothing wrong with a 14SF. However desuading a guy from a 14FF with ground clearance as the only selling point presented I feel is bogus. Like I stated I used a 14FF as it was cheaper in the long run to use it as I have plans for 42s or bigger. I know alot of the AZ guys run 10 and 12 bolts but correct me if Im wrong you guys general have 37s or smaller. Stoopid argument really now that I look back on it. If I had a 14SF I would have built that and run it but I didnt since I was buying an axle I bought a FF.
I guess that is what it comes down to. If he has a 14SF I would use that. If he has to purchase an axle I would go 14FF or Dana 70 that is just me.
Ira
Hey Marv,marv_springer said:Manny,
It is funny to me for this reason....
Have you stopped to consider that this might be just what you're doing.
I know I'm w/ a minority here... but here goes anyway.
The 14FF is a beefy piece. Does everybody need one? I think not. The general sentiment on this board is that you are a stupid noob rookie if you don't have a D60/14FF combo under your truck. Everybody tends to follow this w/out question.... and many times it seems that nobody's thinking about what they really need - they are just gettin' what's deemed "cool" by the crowd.
And while I don't criticize people for swapping in 1 ton axles, I sometimes tire from the notion that you can't drive off the pavement w/out them. For many of us, wheeling is more of a "balance" of what you can do w/ what you've got. This tests the driver, and illustrates that there is more than one way to skin a cat.
Now, I realize that your thing is mud. I try my best to stay away from the mud, and I tend to like rocks and sand more. But suffice it to say that I've done alot of wheelin'.... and have yet to run a D60 Front or 14b Rear under any rig I've wheeled. Don't misunderstand me.... I'm not saying that everybody should wheel 1/2 ton axles. I am saying that you shouldn't always "point and giggle" when you see a rig on 1/2 tons. You just might be chasing it up the hill....!
Respectfully,
Marv
sandawgk5 said:I would go with a 14FF as they are cheaper to find and cheaper to build. Sit down with him and give him the breakdown of rebuilding, regear, and locker. That and the selections for a 14FF are better ease of gear setup. That does not even get into the strength differences. I personally feel it is a waste of money to not use a 14FF unless he already has the other axle and it is setup the way he needs it and it is ready to bolt in.
Ira
My bad, he's already converting his front to 8 lug, has the parts, and already has the wheels. As far as the e-brake is concerned, as long as he has the 14 bolt cables, it should be a direct bolt up. That is what I have read here in CK5. If wrong, please correct me. I don't want to mislead him.bajaviking said:Please remember to tell this young friend of yours that he will have to buy new wheels, he will have to spend money on getting the front converted to 8-lug,he will have to spend money to get his e-brake working, after doing all that the 14 bolt FF is not that cheap anymore plus it's a lot more time to do the work.
I keep my rig as light as possible and run 35" tires with a 10B front(locker) and 14bSF(welded) in the rear and I beat the snot out of it in the rocks, sand, trails, everything. I have broken the front shafts a couple of times but never the rear. If I was going to go bigger I would probably want to go 14BFF but then I would also want to go Dana 60 and with that bigger tires, gears, 8 lug wheels and who knows what else and then all of sudden we are talking mucho money.
Each to his own but for me it was easier to just throw a 14 bolt SF in it and be done with it. You don't need 44" boggers and 1 ton axles to have fun.
.MuddinManny said:My bad, he's already converting his front to 8 lug, has the parts, and already has the wheels. As far as the e-brake is concerned, as long as he has the 14 bolt cables, it should be a direct bolt up. That is what I have read here in CK5. If wrong, please correct me. I don't want to mislead him.
Agreed...I've had fun from 31's to 38's. Now I'm going to 39's and see no point in 44's for me. Each time I had great fun!
Manny
MuddinManny said:There is nothing wrong with a 14BSF axle. It has it's purposes, but if you could get a FF for the same price as a SF, the advantages of a FF far outweight a lousy 1" of clearance, especially in the MUD.
Beater, I've had 4 trucks under my belt that I've mudded:beater_k20 said:Manny, have you ever actually had a truck that was worth its scrap price in the mud? less weight, and more ground clearance are EVERYTHING in the mud.
Even so, to a full-size, 1-2" of a lip on a 14Bolt isn't going to make or break you in the MUD. I don't care how you cut it, slice it, or jam it. Even in ruts, if you bottom out on the 14 Bolt chances are the ruts are too deep for your tire or close to the depth to begin with. More than likely you'll lose traction anyway. Every situation is different, and if there is one thing I know about mud, it's anything but consistent.
