bp71k5
3/4 ton status
Weird, how is the fender lining up with the hood lines?
Is that an aftermarket door?
I actually have had the same problem on mine just not quite as bad.
You might try adding more shims at the rear of the door and then adjusting the hinges to match it back up.
How thick are your shims? My two shims are about a total of 1/4" thick, maybe a bit more even.
3" bodylift.Yea, a 1/2 inch isn't that out of bounds, but it seems like you should be closer than you are. I assume you don't have a body lift right?
Ah, the body lift may throw your calculations off a little, but the hardtop being too far back sounds like more of the culprit.
It sounds like the windshield is stopping the top from coming forward. I think the windshield is layed back. Gaps look nice (except windshield / door frame). It may just take some brute force to bring the windshield frame forward a bit.
lol....so i sat in the drivers seat put my feet on the top of the window frame and started to move the frame when all of a sudden my seat gave out and i broke the seat. My seat is now a recliner, and it wasn't when i started.![]()
. lol....so i sat in the drivers seat put my feet on the top of the window frame and started to move the frame when all of a sudden my seat gave out and i broke the seat. My seat is now a recliner, and it wasn't when i started.![]()
So....remember, if you pull your front clip off, the firewall and windshield frame will relax back to their old position.
Jim - I'm laughing with you
But the old adage about "if it aint broke, don't fix it" comes to mind here.![]()
