I drove the 73 at night for the first time and I noticed the lights are cycling in brightness. It's the headlights and dash lights. The previous owner wired the light for the aftermarket tach straight to power and it cycles also so I suspect the entire electrical system is doing it.
I also noticed the dome light cycling during the day with the headlights off. The needle of the tach seems to move with the cycling lights and I think I can hear it in the idle a little to.
I had noticed the ground strap between firewall and engine was disconnected. So today I installed a new one I had on-hand. I also cleaned up all the grounds I could see in the engine bay; battery to alternator bracket, battery to frame, firewall to block, battery to core support, and both headlight grounds. In addition to that I also installed relays in the headlight wiring.
I also tightened the alternator belt. I even put some belt dressing on the belts.
After all that, the cycling is still occurring. If anything it seems like it might be cycling faster. The lights don't go out, they just cycle in brightness.
Before I started the work above, I checked the battery voltage with the truck idling. It was cycling between 14+ to 15+ volts (the + means it was some decimal value). I didn't really think to watch the voltage long enough to see if it was cycling the same as I noticed the lights were. My focus was making sure the battery was charging, and I really thought re-installing the firewall to engine ground strap was going to fix it. This truck has an amp meter, and it doesn't move.
It doesn't seem to cycle when stopped in gear idling about 600RPM. I start to notice it when idling in Park, which is about 750RPM. It's gets more pronounced as the RPM increases.
I'm suspecting there is something wrong with the alternator. I can't figure out if this truck has an external regulator. It's definitely not where the regulator is on the 66, and I can't find one anywhere else in the engine bay. If it's there, it must be tucked in under or behind something.
My guess would be it has an internally regulated alternator. Based on the little searching I did, internal regulating started about 1973. I"m thinking if it could have been either way, this truck probably is internal because it has AC. On the other side of the argument, the truck has the amp meter not a voltmeter. I always thought that change came with the use of internal regulators.
I don't want to just replace the alternator because if it is externally regulated, that might be what's failing. Not to mention the whole problem of putting the wrong alternator in.
Any thoughts would be appreciated.
Except I'm taking out words like "might".
