Help with Engine build
mtnman210
Northridge, Ca
So I'm gonna dive head first into building my first motor from a bare block. First off this is the parts list I'm looking at. Feel free to add comments and insight. This motor will be strictly offroad only and would like to balance reliability with cost.
I haven't checked out many different places yet so this list is based totally off Summit's website.
Eagle Rotating Assembly: 999.95
cast crank
5140 steel connecting rods
FM244 aluminum alloy hypereutectic pictons
perfect circle piston rings
Clevite 77 bearings
harmonic balancer--extra
flexplate--extra
OR INDIVIDUAL PARTS
Parts
Balancer: Summit Big Chevy internal balance: 219.95
Crank: have a 2 piece main that will need to be grinded to fix scored bearing journals
have a 1 piece main in an unknown condition--know by 5/17
Eagle cast 2 piece main external balanced: 275.95
Eagle 4340 forged internal balanced 795.95
Main caps: have both old sets off eaither motor
new Eagle main caps 89.95
Connecting rods: Have both old sets from each motor
new: Eagle H beam: 459.95
Bearings:Speed Pro Main:52.95
Rod: 54.95
Clevite H series: main 63.95
rod: 63.60
Pistons: Keith Black flat top: 359.95
Dome: 399.95
speed pro dome: 415.60
Rings: speed pro 115.95
Oil Pump: have old
new Sealed Power high volume 38.95
Oil Cooler:B&M supercooler 119.95
Oil pan: have
Valve Covers: Have but would like new
Heads: have 049 heads that I would get work done to get better flow. I don't know pricing
on this but I's say in the neighborhood of 1000
Cam: No idea on what to get here I figured I would talk to comp and find out what they
recomend. roughly I'd say 180
Lifters: Have the old ones.
New: comp cam hydraulic roller lifters: 459.95
Valve springs: have the old ones
New: No idea what I want here but comps dual springs are in the range of 300
Reatainers: Compcams steel 54.95
Push rods: comp cams push rods 229.95
Rockers: comp cams steel 159.95
Valves: dont' know the numbers here
Mideon intake 87.95
exhaust 99.95
Timing gears and chain: Comp cams 107.99
Timing cover: have
new compcams: 140.69
Gaskets: 274
Bolts: ARP kit 100
Thermostat housing: have old
new 100
water pump: have the old
New: Mideon high volume 109.95
the eagle stuff although chinese made isnt bad really. the kits put together from summit or jegs will save you more on the major stuff. machine work can get expensive if you have to recondition alot of parts. the cast steel cranks in the eagle kit or scat are stronger than a factory cast iron crank.
one thing to consider is yes the eagle cranks are cheap but, i worked for a engine builder and it was his experience that the cheaper eagle cranks ended up costing as much as the good ones because they took so much longer to balance
I'm not set on Eagle at all thats just what I've found. If it's Chinese steel I'd rather stay away from it anyway.
Powerwise...this motor is gonna be for fun. But at the same time I don't want the wrong type of power. I'm not racing the truck but playing on trials, Some good high rpm mud runs and desert type wheeling. Also the 454 crate motors come with 450hp and 500lbs for around $5000. So I figure if I build my own motor for around the same price I should be able to squeeze out a little more HP and Torque.
Dude, you're within a few miles of P.A.W., one of the larger engine kit outfits around. They're located at 20235 Nordhoff in Chatsworth. They sell on line, etc. but you don't even have to pay shipping (tax yes). Their Chevy catalog is about 2 inches thick. Website: http://www.pawinc.com/ Have a look.
HOLY CRAP!!! I completely forgot about PAW. my 350 was built through them:doah: Thanks for that reminder.
to get away from chinease steel your gonna have to spend a bit. some of the cnia stuff isnt bad really. the eagle stuff can be a pian to balance, but it depends on your bobweight as to how dificult. the scat stuff is ok too, i have run there cast 9000 cranks in a few 383's for drag racing, turning them 7500rpms, with a 200 shot of nitrous and not a single issue. if you have a nice fatory crank just have it turned if needed or polished and run it, make sure they check for straightness too.
My suggestion would be to save money and go with the flat lifters and solid rockers. You really don't need the high rpm stuf....unless maybe your mudding, etc. Also, the factory stuff will hold up very well in the power range that you are looking for. Might save some coin there too. Just my thoughts....
