How does it do in other applications? Ie bikes, etc.
16 oz good enough? Cleans out ethonal?
Use it in anything! 16 oz will treat about 16 gallons according to the label. I'm not sure if it "cures" ethanol in the fuel.
Ok, got the Seafoam tonight. Have not put it in yet. Decided to work on something tonight that I could completely accomplish tonight.
I have to say, this truck is beginning to reach my critical piss off point. There have been so many "are you kidding me" things that I could expect anymore.
So, tonights; went to replace the power window switch on the driver's side. Popped the door panel off, replaced the switch and reinstall the battery cables. Tried the switch.....nothing. Hmmm? Test power to the switch, good. Test the new switch, good. Go to test the motor...motor...motor...were the heck is the motor?
No motor and no track that it rides on. Are you kidding me? Why am I doing this again?
The switch was physically broken. Was it broken to hide the fact that the motor was gone, I don't know but I am beginning to see a pattern, like the motor. I have no issues with the K5 series of trucks. Right now I own 2. I have owned 11 of them so far. Just all being older than the '87.Not trying to be a downer but doing a radical motor swap is only going to add its own problems.
The window thing is a perfect example of guessing compared to proper diagnostics. I would go out on a limb to say the old switch was probably still good.
Sounds like you got a lemon of a truck. That can happen with any vehicle foreign or domestic. Don't judge the breed by one bad seed.
The way I look at these kinds of things is at least when you fix something you know you won't need to worry about it for a while.
Yea, hate to hear that this thing is giving you such a hard fight. But its really tough when you go buy a used truck like this and don't really know the background or long term history.
Hope you'll keep plugging away. At least you're fixing things and getting somewhere with the project!
Many people neglect to clean and lubricate the window tracks when they need it. Mine were slow going up, you'd have to grab on and help them up sometimes. Took the panels off and hit the regulator and rollers and tracks with spray white grease and the rubber channels with spray silicone. They go up so fast now you'd think it was a brand new truck.
