sled_dog
1 ton status
yeah, that was what I feared. Eh, parking brake will be one of the last thoughts so for now, not worried about it
biggest reason i had for using a t-case mounted ebrake was cables of a stock type setup being in harms way under the truckk5freak44 said:lol you said dick
if you are comparing these to caddy caliper ebrakes, price wise, caddys come out cheaper
ntsqd said:You really don't want to go there for long term use. Like parked in your sloped driveway. Something like this can work for short term apps. Like getting out of the truck to look where the rock under you rolled to.
The problem with long term is that the pressure will bleed off. A good system might take days, or it might not take that long and then your posts would be missed.
Something like the Jamar Park-Loc can be put in your service brake system for the short term uses.
CyberSniper said:My electric line locks will last longer than my batteries. It takes like 18 hours to kill my batteries enough so it wouldn't start... but the linelocks were still holding. If you're going to be parked more than overnight you should be using some kind of mechanical anti roll device to stop it. IE: not mechanical or hydraulic brakes. Leaving your vented rotors clamped or your drums expanded for extended periods of time isn't the best. I wouldn't worry about solid rotors.
surpip said:Keep in mind also tha there is alot of heavy equipment that uses drivline e-brakes. We have a aircraft tug here that uses one, im going to try to get an idea for mine off that system, looks fairley simple. Im am going to try to see if i can get a exploded view of it off the maint manul. and post it up here.
those look good, to bad they dont list pricesTriaged said:The caliper that Jess used in the 205 e-brake is from an aircraft tug.
You might want to take a look at this
http://www.hayesbrake.com/pdf/2002-HayesBrakeCatalog.pdf
Let me guess... The smaller tug is an A/S32A-42A, and the bigger tug is called a "Buddha". I can't remember the designation for it, even though I was licensed on it...surpip said:both of our tug's here have mech. disk brakes. Im going to bring my camera to work tomorrw and take pictures of both the setups, i just went out side and crawled under the smaller one, it looks like it would be pretty easy to adatp one to our trucks. I am going to do some reasearch to see ho much these systems go for.
the one tug weighs 43,000lbs...
we used to have the 32a-42a in prowlers, but here we have the 32A-30A, pretty much the same thing but a little smaller, and it has a cab, and ya we got the Budda tojarheadk5 said:Let me guess... The smaller tug is an A/S32A-42A, and the bigger tug is called a "Buddha". I can't remember the designation for it, even though I was licensed on it...
big pappa b said:I found the prices listed on his page. It's under "driveline cutting brakes"
http://highangledriveline.com/driveline_e-brake-cutting%20brake.htm
we use it to pull around our power carts and stuff like that:
