78 GMC Jimmy
Any Idea when you could ship it out? Do you accept PayPal?
Looks like you are in luck.Looks like the seal is about 2 1/4 by 3 & 1/16th ish?
On the seal lip it says:
pt-103 seal nok servis
Any idea what seal that is? Cant find one on Amazon.
Can anyone send me an Amazon link to a seal that would work?
Possible size:
3.066 OD X 2.125 ID
I will not spend time to clean it up much for $10 but you can clean it up.
It's in good shape and the ubolts are too.
Do you need the washer on nut?
Or yours are still good?View attachment 489684
9168715548My whole setup took damage. The nut is in marginal condition, and there was no washer, so I found a washer that was close enough. So ya, if your able to send the washer and nut that would be ideal, but i could survive without it if needed.
Is there a number I can text you at to make the arrangements?
Glad you got it fixed.
Did you cut the insulation off the old cable to examine the wires yet?
I know, right?!?!solved on post #9
Classic case of gangrene. It was able to pass enough current when cold but when you add heat that increases the resistance in that one spot not allowing enough current to flow. I’m sure if you felt the wire at that one spot when it wasn’t working it’d be hot.If any of all yalls wana see the positive battery cable, here it is.
Worked absolutely 100% of the time cold.
Worked maybe 80% of the time hot.
When it didn't work hot, you could wait a little while or open the hood, and that would cause it to work again.
Locally:
One guy said 90% starter.
One guy said 90% timing.
One guy said 100% battery.
One guy said most likely carb/intake issues.
And so on. .
Some of the local guys said its either the battery, carburetor, distributor, starter, electrical, wiring, ignition switch or something else".
So your saying that something is wrong between the front bumper and the rear bumper... Great, thanks.
Unfortunately it was really hard to track down, due to how inconsistent it was. By the time you get back to the shop, its working great, so there is nothing to fix. Or its not working, and you try something and that solved the problem, so you assume its fixed. A week later the problem returns and you try something else, and the problem goes away. So you assume its fixed. Pulling the thermostat fixed it for a very long time, but then the problem came back when the weather changed.
The cable looks fine except for the oxidation at one end. But the wires are intact, not brittle or broken. How could the oxidation only cause a problem when at a certain temp? How could it be THAT close to not working, but work GREAT when 10 degrees cooler?
Pics:
You’re just looking at the corrosion on the surface. If you cut the individual strands you’ll see that the cross sectional area of good copper is less than what it is on a non-corroded strand. And remember, if you decrease a circle’s diameter by half it is not half the area it’s 1/4 the area, so it doesn’t take much of the cross sectional area to be eaten away to start having an effect on how much current can flow through a strand of wire.
Makes sense to me. I had felt the cable from one end to the other when it was not cranking properly, and I could not find a hot spot. Maybe the insulation was too thick. During the times it had issues, its strange that it would work when the distributor was turned off, but not when turned on. All signs were pointing to the distributor. Until a new distributor was installed....
So far so good. I sure hope this is not another "fix" that turns out to not fix it. It working properly for a few days was not uncommon - just to have the problem return with a vengeance.
Its possible.By disabling the ignition, allowed the engine to turn over easier, with out the flame front pushing against piston. Once the cranking speed was up turning on the spark would fire and run.
No spark= less work for starter= less current to crank
