dmcx72
Iron horses in thin air and thick.
Alright. I've had this truck 10 years and I finally have the sense and cents to do something with it. HOJ is his name and it stands for Hunk of Junk.
Here it is:
Talked to Steven yesterday at OffRoadDesign. He talked me into finding some 1-ton axles. I will be moving from Louisiana to California this fall, so the plan at the moment is to:
0. Get the motor out and install the new HD first-gen crossmember from DIY4X (new version has removable crosspiece)
1. Find 1-ton axles and swap-em out
2. Install ORD 4" shackle flip (with all the accouterments, bushings, HD shackles all around, etc) and springs for 6-8" of lift total
3. Install high-crossover steer w/ hydro assist
Looking to run 37's or 38's when it's all said and done.
Went to the junkyard today and found a couple 14-bolt rears in Chevy 2500's and one 3500. I'm just not sure now which ones will swap in directly with my 12-bolts. I remember Steven saying that certain ones were a direct swap, but now I don't recall. Can I get a pointer on axle swaps?
More later ... bed now!
-DC
Here it is:
-DC
What sort of tools and experience do you have? If you've got a welder and a 4-1/2" grinder the swap will be straightforward. You'll at least need that grinder to cutoff dozens of rivets to do the shackle flip anyway.
I think we'll just keep it simple for now.
