Is the stock HP on a 91 350 @ 210?? What is the torque rating on those motors?
91 suburban 350 TBI 3/4 ton yadda yadda yadda???
In my Chiltons it only covers up to 1990 but the HP for the suburban varies depending on R-V 1500 = 210 @ 4000 rpm or R-V 2500 = 195 @ 4000 rpm but the torque for both is 300 @ 2800 rpm
ug, so 195 hp on 5.7 TBI? That's terrible on a few different scales!![]()
In a truck or wheeling rig you should not even be concerned with HP, it is torque that gets you moving and is what's needed for low end crawling and such. HP is a big concern for the race car guys. Just remember, torque gets you going and HP keeps you going (on the top end).
Depends on the wheeling you do.... hillclimbs and mud hp is important. Crawling trails, and rocks tq is important.
The stock 350 is ok for mild trail running but it was painfully obvious how underpowered it was when towing or even running up hills with no trailer on the freeway. I needed to regear but still it was pretty bad.
Well, this is more a towing application so I do need some good low end torque as well.
If you want torque, put pontiac power in it!
For the Sub go with a good 383. You will have good torque and avoid the hassels of swaping in a BBC (smog, accesories etc.)
My burb got around fine on the 265/75r16's with 3.73's
What gears are you running?
I've got 315/70s and 4:56 and when towing my boat it's a pig. In 4low in the woods it's fine. On the hwy the .75 OD is a win for sure.
