Vombrown
Mountain Man
So the long and short of this thread will be my build of A 6.2 mechanical pump turbo engine. This setup will going in my 72 suburban build in front of a turbo 400 trans that will also receive enough help to take the stress.
Right now I am at the tear down and order parts phase. I am starting with whAT Appears to be a later model 6.5 block. I will strip it down and send it out to be checked and cleaned. Cylinders look good but we may bore a small amount to clean everything up. We will balance the entire rotating assembly. Replacing pistons for coated mahle versions. Arp rod bolts to replace factory spec stuff. When everything comes back i will clean up the ports on the head and gasket match them. I will be having. The block and heads checked for squareness and decked if needed. Arp head studs and copper head gaskets to hold the boost i am planning to dump in. Follow along as we get it going. Block heads into the machine shop tomorrow.
