guido666
Ah, I hadn't thought about the tire being stuck case. Would it still help in the wheel spin up case I described though?
I run in 3WD (1 hub unlocked) on the road when it's snowy or icey out, and have no problems there either. As for turning around, and turning the wheel
I'm not sure what problems others are facing, but I have none, it turns just fine for me
guido666 said:What happens that makes a LSD "scary" on ice/snow?
guido666 said:Interesting that now people are coming back with good feedback for a welded/locked front end.
How often do those of you with locked/welded front ends drive on the road, or are your trucks just trail rigs (no offense intended if they aren't).
Deep snow you can't beat it.
On the trail I keep it in 2wdr until I hit an obsticle I know I can't make with out 4wdr. After the obsticle I go right back to 2wdr. Using a rear locker or welded in 2wdr your probably almost as capable as an open truck 4wdr. guido666 said:Interesting that now people are coming back with good feedback for a welded/locked front end.
