How many of you that are 3/4 or 1 ton have busted 1/2 ton stuff?
I actually broke the axle tube in two pieces on the front 44. Then I went to Dana 70's with THICK tubes. I had braking problems though and swapped the front out for a 60. Now I recently broke an axle shaft in the rear 70. But I seriously doubt I broke it. I think there was something wrong with it already. I can't get it out to look at though, so I just put a 14 bolt in it's place.
Oh yeah, back when I only had 35's and a 12 bolt rear, I blew up the carrier once, and another time stripped the teeth off the pinion, several teeth off the ring gear, and broke the ring gear into two completely seperate pieces.
if one comes in my lap for sheap
This is not that type of website /forums/images/graemlins/eek.gif
Me
[/ QUOTE ]Let me elaborate... I broke the 10b on my stock Tahoe. I broke the front 10b on my Cheyenne (but I also had 39.5 boggers on an open diff)... etc etc /forums/images/graemlins/thumb.gif
nope cant say ive ever broke any 1/2ton parts..... /forums/images/graemlins/thinking.gif of course i started out 3/4ton though
I broke my rear 10 bolt. Rebuilt it with parts I got for free. Now I have a 14 Bolt Semi-Floater. No full floater for me, I dont need any more places to get hung up on.
I started out with D44 w/260x ujoints and rear 12 bolt, both open, on 33" all terrains. I really didn't four wheel much so I didn't break anything. Then I went to 3/4 ton with D44 open front and D60 welded rear on slick 35s. I finally broke the spiders in the 44. Replaced them and wheeled for a while until I got 39" TSLs. Then while going through a deep mudhole full throttle, I broke the spiders, both front u-joints, and distorted the ears on all but one shaft so I had to torch the ears off to get them out. Also broke rear driveshaft and both u-joints and rear pinion yoke. Then I went to front D60 and broke 3 rear shafts. Then I went to 14FF rear w/Detroit and haven't broke axles since.
Will
Just put it this way when me and Ken (whitewhomper) got to where we could change a 44 shaft in 23 minutes on the trail and be back wheeling I decided we were getting way way to much practice. That was with 35's. He would break 3-4 a season and I would get 4-5 mostly long side shafts. Only broke the Gov lock in the rear.
Problem is now I have started to break my 60 /forums/images/graemlins/confused.gif Must be something in the air /forums/images/graemlins/rotfl.gif
