Confedneck79K30
3/4 ton status
nice, really sharp!
. A filter/ water/ oil seperator would be real nice too. It would keep your tools runnin nice
Avery4jc said:Oh, and back to the converter...I got a male PVC fitting that threads into the tank and accepts a small bushing that has different size threads so I got the one that said 1/2" because I measured my hose before I left and it was 1/2" on the outside and 3/8" on the inside...when I got home it was to big...when you measure something like that do you measure the diameter of the hole or the overall diameter including the threads?
Dont oil yer lines if you are gonna use for painting...Oil yer tools...Avery4jc said:Yeah I've already got a 50' hose...I had it from my other compressor.
Avery4jc said:So I'll be able to find one that drops from the 1 1/2" female coming out of the tank down to 3/8"? (Assuming the regulator is a 3/8" in and 3/8" out sort of deal...)
nerraw117 said:let us know how it runs your impact
88sub4x4 said:Check out this one http://www.lowes.com/lowes/lkn?action=productDetail&productId=236704-48540-K7045V&lpage=none
It's only 399 in store too. I'm gonna get it once the power company upgrades the lines here, until then i'm stuck using an 8 gal, gas unit. it works pretty well, but have to kill it at 9pm so the neighbors stay friendly.
GruntHunter said:![]()
I've been looking at that compressor also. I'm not looking at trying to paint a car or anything big like that. Most of my painting has been with small projects like metal hunting stands etc. I would like to be able to do small painting projects and maybe sand blasting small parts. The biggest thing I probably would ever tackle is my 6x12 Utility trailer.
Bottom Line question: What pressure and how much scfm do you need to do projects like this?![]()
