black dawg
a 3r is similar to a 1330... in my experience slighty tougher. Like already said though I wouldnt waste time and money into a shaft with 1/2 ton stock sized joints on a not stock sized truck.
How do you like it? I may end up going this route.
I like it so far. Ive wheeled it a few times and played in the mud a bunch too, and i like the fact that i can trust a Chromoly tubed shaft and 1410s up steep inclines in a heavy truck and know thats not my weak link.
Ive had joints fail on me in the worse location or incline and said to myself " this will never happen again"
Now.....i have also noticed a slight vibration when in 4X4 when driving on the streets in the winter. Where i may go 50 mph or so for a given couple or miles.
Ill trade the short trip, high speed driving vibration for the known strength going up a rock or when im in 4LO x2 any day.
Mastiff, just go 1310 so the working angles are enough. Ask yourself an honest question, how hard do you beat on your truck? How often? How far from home or tow company? Etc
I may not be running in rocks, but mine is spinning at high speed over bumpy terrain, going from bump to droop constantly and the front shaft has given me very little issues.
I had to rebuild the center ball thing at the beginning of last year, but it was the stock joint, so I think it served its purpose... (still had the plastic injection stuff instead of c clips that needs to be melted out with a torch).
Do you have the 3R CV? IIRC, that was very limited in angle. I'd stick with it otherwise. I'm sure you droop as much as I do, nearly 30 degrees.
None of the trucks mentioned in this thread are very tall so this should be a very easy application to fit. I have 8" on mine and the single joint (1410) shaft I'm using is smooth as silk with respect to operating angle when flexed. Mine isn't balanced and may not be the best for interstate speed 4wd but that's not a concern for me. With the low lift involved and not making crazy high hp, the 1310 CV should be fine. The only thing I'd do different is step up the axle joint to a 1350 to cut down on spare parts needed in the tool box.
Oh yeah, I agree and I should have worded it a little different but my reply wasn't directed and you or anyone specific. Just - IMO - when you're dealing with lift at or below 8" this really isn't a huge issue that requires mega dollar driveshafts.
Depends what you consider mega dollar. Looks to me like a 1310 shaft will be $500 and a 1350 would be $650-700. That's real money. Admittedly, this is driven partly by ORD springs which need a lot of travel. The angles aren't crazy, but well out of stock range.
Ah ok! Yeah for us its not much problem. Ill probably build a cheapo square shaft to deal with my droop. Thats why they exist!
