How to get studs out of water pump
90K5
Lubbock, TX
Just changed my water pump, but its got four studs that the fan bolts to...how can I get these out? They are threaded studd and I don't really have any way to tur nthem without messing up the threads...Anyone just used bolts?
double nut it with a washer between the 2 nuts tighten them together and then put your wrench on the bottom one and screw it out
That is what I do, too.(double nut) But if you cant get them out new studs are cheap, look in your parts store's "Help" section.
