F3RR3T
on my buddies car the emergency brake handle has to be up to start it
once it starts ya can put it down i like the idea
more info pleasextrmjoe said:hidden kill switch, and you needed to turn headlights on to start it.
Well you need to use a relay. Relay's took me a little while to really understand but get a diagram and it should be pretty easy to figure out. basically you need to choose how you want to kill it, starter, coil, ecm, elect fuel pump etc. You use the relay to break that wire and use a hot wire off the headlamp switch to activate the relay and connect the wire. I did one where we broke the starter so that you only needed the lights on to start it. If you use any of the other items to kill you need your headlights on to drive. I liked that though because it gave me a reason to be safer and have daytime running lights.BIGBLAZE433 said:more info please![]()
Do you have pics of that last rig steve???
I can't believe there are people out there that leave the keys in their cars. Small town or not... Get a key ring and put all your keys on it. Heck I feel naked without mine along w/ my wallet
