How to remove tire warning on 17 2500 van
So it may be required on cars and suvs it’s definitely not required on 1-tons.
I’m in the market for a new truck , I’m going back and forth between a Ram and Ford SRW 1-ton. Back-up cameras and parking proximity sensors are NOT standard they are optional.
You looking at gassers or diesel?
You can thank a handful of morons for the TPMS and not being able to adjust the target pressures. Not sure what I'm going to do when I finally break down and buy another truck. My '03 came factory with the 80 psi E-rated tires and I ran the rears at 45-50 psi when not loaded for a better ride, but was also smart enough to pump them back up to 80 when hauling a trailer. The replacement tires are D-rated with a maximum of 65 psi.....don't run heavy enough to require the 80 psi tires.
I will say that back-up cameras are nice, especially with a big ol' pickup truck. Backing up to hook up to a trailer is really nice on some of these models also. Absolutely no guessing or getting in and out of the truck to see if you are lined up.
I just use the tape over the light method, or ignore the light all together.
If you do the pressure pipe method it has to move the sensor goes to sleep when stationary, hang it under the body by a chain so it swings a little.
When dealing with them in the shop I use 60 oz dead blow on the tire to wake them up
Swetty is right. Most programmers can remove or alter it.
Maybe put a tune on for Norm while you’re in there?
Diesel, since Dodge is no longer offering the manual I’m more open to a 6.7 Powerstroke .
There's still a pile of '18 Rams with the stick brand new on eBay. Some large dealers out there look like they stocked up on them since they're a dying bread. You might have to travel a good ways to get one though...
I always order my trucks , but I waited to long .
FYI regarding the comment that back-up cameras are optional. Per the federal law only vehicles below 10,000 GVW are required to have them. However I was looking at the Chevrolet website and it clearly states that back-up cameras are standard equipment on the 3500HD trucks. Even went through the whole "build & price" series and picked the dual rear wheel version and all of the most basic trim levels and in the end it comes up under "standard equipment".
But semis don't have them...do they?
I've seen test on those old explorers going flat while driving. Turns out the rollovers were caused by drivers freaking out and overcompensating...
The test was an air valve attached via 3 1" air holes that was operated remotely.
Found it
Clicky
Found it
Clicky
Cause and response are often not linked on stuff like that.
This is a really neat podcast on the Toyota stuck pedal/ floor mat thing.
http://revisionisthistory.com/episodes/08-blame-game
