Mine is solid to the frame in 10 places. No rubber mounts even on suspension. I wear ear plugs going down the road. But it was built for non pavement use.
Thanks for the replies guys!
Kert, maybe i was thinking along the same line. It seems that the purpose of these is to prevent the cage from coming crushing through the floor board in case of a rollover. The way these are designed it looks like they would pivot if force was applied to the top of the cage and kinda defeating the purpose.
Am I way off? School me.
-Phil
Mine was tied into the frame solid and I didn't notice much of a difference. There was no noise difference and I don't think the ride changed much but my PRP seats probably had something to do with that.
Kert I would be interested in something like these also. It's coming close to address a cage on my vehicle also.
I have a part drafted. Backward engineered to be compatible with our existing staked cage floor plates. I'll have to see if I have a punch and die short enough to do the job. Punch I think is no problem.
Everytime I've seen these used, it seems to me the axis of the bolt needs to be rotated 90*. It would appear they are mounted the simplest way but not necessarily the best way. Only way I know to describe it, with the bolt one way its a hinge. Bolt the other way its more likely to be a supporting piece. This is considering the force applied from the direction of the cab toward the frame. I think that is the most important thing to consider for this particular piece.
. I agree with you Kert, should be @ 90 deg. You would still get the fles effect of the bushings this way too. The way their mounted in the pic there is no cushion, just rotation like a hinge as you said. Thanks Kert for considering doing these for us, I'm stoked, glad I proposistioned ya on these. I thought about it a bunch and decided I was not going to tie to the frame but I really would rather have it tied in, having these will make it easy to do so. And give you another awesome product to sell. I can do them, got to cut a die set down to fit in the spot.
Something like that?
I'll do the best I can on price. My version is significantly different. 1/4" plate to begin with as well as 1/4" DOM tube. Second, throw in the anti shear pin and the hardware as well.
One thing, I don't like to use the locking flanged headed bolts, tears the hell out of powdercoated or painted parts. I like the extra think grade 8 washers and regular grade 8 bolts with nylock nuts or crimp nuts. Will the tab be too close to the holes to not allow that type of washer?? Other then that there awesome! Nice added touch with the shear pin too.
I could set you up with the pinch lock nuts. Don't have any other style of bolts though. Regular grade 8 stuff should work just fine though.
If I were in socal, I wouldn't paint a damn thing!!![]()
. So when can I order these Kert? I'm ready when you are. I will take one Doz. I have some ideas for other uses too. Do I get props for bringing these to your VAST array of awesome fabbed parts list? Lets see, I have these and round cage floor plates I added to your parts list I will take credit for.
Hay! we get rust here too, trust me we do. I hate West coast rust just as much as East coast rust..... Well, maybe not QUITE as bad![]()
Should have all the office type details worked out by this evening. Then they'll be ready to go.
I'll take care of ya!
