How will my K5/truck look with xx" tires on xx" of lift?
3 inch body lift, minor fender trimming and 35" MK2's
Who did you get your 1.5" wheel spacers through? Also, did you stay with standard SRW wheel studs for the rear or upgrade to the 1 ton DRW ones?
Just noticed that I never posted in this thread:D
Stock Height, No Trimming, BFG T/A KO 30x9.50r15's
Stock Height, Lots of Trimming, BFG KM2 35x12.50r15's
here's my piece
ord shackle flip, 7" shackles, stock 56" leaf pack(7 leaves), zero rate, out back
stock 56" leaf pack(6 leaves) zero rate, 7" shackles, front mount moved forward
14b/d44 - 38.5x14.5x15 tsl sx's w 20psi on 15x8 wheels
keep in mind this is with little interior, no fuel tank, and no motor, so it will probably lower down an inch or so once its all back together.
fender cutting coming soon!
He may need fenders first but at least he's going green with the power output. Al Gore would be happy.:D
1979 GMC Jimmy
8 Inch all leaf lift
37 inch boggers
corprate 14 bolt in rear
work in progress
A lot of awesome trucks in here. :cool:
Mine's a 74 with 4" front springs, ORD shackle flip and 1" zero rate in rear with stock worn springs. 33's
(now I want to go bigger) :D
Orange85, that's an awesome paint scheme, is it intended to resemble the Mako Shark Corvette? I was thinking about that with one of my trucks and the guy that was going to paint it for me didn't have a clue what I was talking about :-(
